OK I am trying to change the thermostat got it all back together and I have a leak somewhere. Am I supposed to use some sort of sealer? Anyone?
Some silicone is fine. Don't forget to install the t-stat spring-side into the intake manifold. Give it a smear of RTV all around the _clean_ mating surface of the thermostat housing, drop in the thermostat spring out, and bolt it to the _clean_ mating surface of the intake manifold. Don't tighten the daylights out of the bolts or you'll squeeze all of the silicone out and it won't seal.
green ones make me horny
yes you are they make some grey shit that is made for t stat housing. also make sure you have pinched the t stat at the bottom of the housing. i did that and it pissed me off
