1 - 9 of 9 Posts
Banned
Im replacing the thermostat and the water outlet. I got everything on but this damn thing is leaking now. There were 2 gaskets, a paper gasket the other is a cork gasket. Am i suppose to use both or just one or the other that came with the water outlet and thermostat? The only one i used was the paper gasket and when it started leaking i took off the water outlet and now the paper gasket is trashed. Not thinking about it i returned the cork gasket before I replaced the thermostat and the water outlet.
Thanks for any help. Do i need both or should i go buy another cork gasket?
Rest in Peace Friend...
You should be able to get a new paper gasket form a parts store. If you clean the surfaces real good it shouldn't leak. I usually add some RTV on the surface to help hold the gasket in place while putting the pieces together.
Good luck,
Lick my balls
I've never heard of cork being used on the therm housing. You could always make your own gasket from a cereal box if you have to, and use some kind of gasket glue and you are good to go. Just make sure you remove all the old gasket material. Plus the combination wrench is the only way I know of any ways to remove that one bolt.
replaced mine a few weeks ago and first time around therm was'nt seated, just like muddybronco13 posted. i held the therm in place thru the outlet hole when i did it the second time. also, make sure yer sealent/rtv is dry before fluids/running. stuff i used had a 24 hr dry time.
and, if anyone knows, haynes & chilton stated my therm was positioned vertically on a 5.8, but no such luck, it's kinda a pain to get it seated right.
When I last changed my T-stat, like a few months back, the gasket that came with it was of the peel & stick varity.....very nice set up for keeping it in place.
1 - 9 of 9 Posts
