I am thinking about selling my Bronco. Not for sure yet but I would like to get an idea of
what you all think it would be worth. So here it goes.
It's a 1982 with a 351W and C-6 transmission.
New Holley Truck Avenger
MSD ignition system, New cap, rotor, coil, pick-up
Extra MSD 6A box that needs repaired
Less than 500 miles on total motor overhaul
No emission components
Heddman Headers w/ dual exhaust, 12 inch glasspacks w/ echoes
Bored .30 over
Balanced motor
Upgraded camshaft
New Rapid fire plugs and Motorcraft Racing wires
New starter, fuel pump, water pump, harmonic balancer
New belts, hoses, battery cables
Has a 4 row radiator and a flex fan
Transmission has about 20,000 miles since rebuild, but has fresh fluid
Factory transfer case
6 inch ttb lift kit
New steering linkage and AGR power steering pump
New 35X12.50R15 BFG A/T KO tires
Both axles have less than 500 miles on rebuild
Front TTB D44:
New 4.56 ring and pinion with Trac-Lok
New inner axle u-joints and spindle bearings
Superwinch manual lockout hubs
Rear Ford 9 inch:
New 4.56 ring and pinion with Detroit Locker
New 31 spline axles with new bearings
Complete new rear brakes
Interior:
Bucket seats with center console
Front lower seat sections need repaired
Dash mat over factory dash pad
Dark tinted windows
New rear window, needs work on the window motor
2 JBL 15 inch subs in custom box w/ amp rack that takes up
most of the rear cargo area
Sony tweeters in upper A-Pillars
JVC CD player needs replaced
Rear seat in excellent condition
Exterior:
Smittybuilt front and rear tube bumpers
Smittybuilt sure step nerf bars
Overhead lightbar with 6 lights
Has typical rust on the fenders
Look at my Supermotors for pics
Have extra parts like:
Matching door panels with lower pockets
Matching rear cargo trim
Front and rear driveshafts
I probably have forgotten a few things, but that should give everyone an idea
of what has been done to this truck. Right know I'm just looking for ideas on what it
would be worth if I decide to sell it. I have owned this truck since 1994 and I think
the odometer shows around 180,000 miles.
TTB for short
its got high miles and rust... i'll give you 500 bucks for it :goodfinge
$501.00 Here. :thumbup
A few things I forgot:
New throttle cable
Fairly new master cylider and brake booster
A/C is all there just needs charged up.
I never recharged it after I overhauled the motor
Have a used set of front fenders w/ no rust
Have a new replacement drivers side quarter panel
TTB for short
$502.50 and not a penny more!
FSB warrior
yup cuz 180k really matters on a 24 y/o truck with 500 miles on the rebuild and all that new stuff:wacko
Good luck, I ended up parting mine out cuz I was gonna keep the motor anyway.
For some strange reason once they are modified they dont hold the value of the modifications:cry
