Yo NYFSB,
Was there much gunk in the passageway?
Inspect the throttle body. Check for objects blocking the IAC passage or throttle bore. Excessive deposits, especially on high-mileage engines, can build up in the IAC passage and on the IAC pintle. Excessive deposits can also build up on the throttle plate, so check for a sticking throttle plate.
Check the passages for carbon build up. If they are plugged they need to be cleaned out.
How to Clean and Test your IAC
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19 @
Code Reader
See my Vacuum leak test in post #11 @
Help with dtc codes and idle
High idle with no applicable codes is usually caused by a vacuum leak,
Other perpetrators are:
Intake manifold leak.
Sticking throttle linkages or throttle body plate is stuck - we had this occur recently! Sprayed throttle body cleaner on linkage atop throttle body and then light coat of WD 40 on linkage. Don't try to lubricate the cable internally.
Throttle Body top view pic in an 88 5.0 by jem270
Speed Control chain is binding, if equipped
Air intake tube is damaged
Throttle body return spring is loose
Throttle body is loose
Idle Air Control Valve (IAC)
"Start the Bronco and bring the engine up to operating temperature. Allow the engine to idle without any driver input to the throttle or pedal. Go under the hood, and disconnect the electrical connector to the
Idle Air Control Valve (IAC). If the engine begins to stubble or stalls the IAC is functional and does not need to be repaired. If the engine idle does not change you should remove the IAC for inspection.
The IAC can pass and still need repair, or it can fail and not need replacing. The plunger and internal spring can get clogged with dirt and oil. This will slow down the air flow and not allow the IAC to function properly. Remove the IAC and clean it. There are 2 halves to the IAC, and you can not buy just one half, but you can take it apart to clean it. But if the internal solenoid is faulty the IAC needs to be replaced." by Ryan M
How to Clean and Test your IAC by Seattle FSB @
TPS Overview & Testing by Seattle FSB @ TPS Overview & Testing by Seattle FSB @
Bronco Forum - Full Size Ford Bronco Forum
Mikey350 wrote, "Does your throttle body have a yellow warning sticker that says not to clean the throttle bores?
Try this: Take off the air intake hoses so you can access the throttle bores. Start the engine and place a piece of stiff cardboard over the throttle bores. That should NOT change a correctly configured engine, as the idle air is only from the opening of the IAC, and nothing through the throttle bores.
If that make a difference, then the throttle plates are slightly open due to the removal of the Teflon coating, or the linkage/return spring/throttle stop is screwed up.
If the engine still runs too fast with the throttle opening blocked, try taking off the IAC and blocking those openings.
What you have done is (supposedly) removed all the "normal" air intakes, and if the engine still runs, you have a vacuum leak.
You could then try leaving the air intakes (throttle and IAC) blocked and cap off the vacuum lines coming off the vacuum tree. (except the MAP line) If one of those makes a difference, investigate the leak.
Check the vacuum line from the vapor canister (on the left side of the throttle, when facing the throttle assembly) (cap it, on the outside chance that the solenoid has failed open) (if equipped)
Pull the EGR connection to the intake and plug or cover it. (if you have wide duct tape, use that to cover the hole)
If it still is running with the throttle blocked and the IAC and the lines from the vacuum tree capped, then you have a manifold or PCV line leaking. Plug the PCV line to the intake, then the vacuum line to the brake booster (if it has it's own fitting on the manifold)
