1 - 8 of 8 Posts
Don't have the number but you're probably only going to find it at the dealer.
Should be $20 from the dealer.
yea thats why i wanted the part number so i can order it online. mahcine shop wants $5 for it. it was suppose to be in today. i just want to make sure i have ti tommarrow. so i can put this sob together.
Ex Navy Nuke
Summit wants $50 so $5 is a good deal. Or you could just go try and grab one from a partialy disassembled engine in a JY. 302 and 351 is the same part.
I ended up having to drive to the dealership after accidentaly cracking mine in half. The dealership that was an hour away... luckily they had it on a saturday, because i was really in a bind for time.
Good luck!
Good luck!
yup im in a bind for time. the $39-49 one is a steel one. non stock for high performance/steel timing chain. not liek its a stang. so ill go cast on this for the $5-20. lmao
i wouldn't worry about that...
look how most other cams are held in.
1 - 8 of 8 Posts
