My 96 is sas'd and I'm trying to get the slop out of my front end. Most of said slop is where the drag link mounts to the tie rod the draglink does not sit in the taper properly. If the wheels are pointing straight I can move the drag link at the tie rod I've removed it and the taper on the drag link looks ok and I don't see any obvious wear in the taper of the tie rod. And the joint in the drag link seems good and tight still. I'm thinking it's the tie rod and it's just had the taper wore out of it. Anyone have any other ideas?
