I have searched half the day and seem to not be able to find an answer. I have a 85 with a 302 in it. While attempting to time it i adjusted the timimg to 12 since it calls for the adjustment to be between 10 and 12. It was at almost 30 before and bringing it down to 12 has made it run even worse.:cry Any suggestions?:banghead
2006 Lincoln Navigator
If you have an 85 and its carbed dont worry about the spout. .Pull vacuum advance,set pointer at zero,pull plug 1 make sure it up.Stab dizzy with rotor at one ,or wherever you want one to be on cap.wire it up and put the gun to i.Mine tuns best at .I found mine to run kike shit at 19,but I believe my vacum advance is busted .For now its at 2 and runs great .Ill get a new advance and try 10-12.
