1 - 8 of 8 Posts
I have a set of Dunlop Radial Rovers on my truck. The tires are expensive but I am looking for new rims. The tire size is 31x10.5. The opening is 16 inches. Would these tires fit stock Bronco rims? Also what size rims should I be looking for if not? Thanks, Mike.
Stock Bronco rims were 15x7.5 or 15x8.
Alright thanks. Then what size do I need to buy so the tires fit?
16x8 rims if the tire rim size is 16"... :doh0715:
Even if the tire says 31x10.5?
ford freak
that is 31" tall, 10.5" wide (aprox) and the number after that is the rim size. if you look at the side of the tire, you will see something like 31x10.5R16 if you have a tire that goes on a 16" rim. if you see 31x10.5R15, then you need a 15" rim.
Thanks everyone. I appreciate the time and effort. The rims will be ordered soon I hope.
1 - 8 of 8 Posts
