1 - 20 of 20 Posts
I want to remove my tire rack and I've seen alot people doing it. What I was wondering was what do I do about the wholes?
Thanks, Travis
Building gold from crap
or take it to a body sop and have em weld up the holes and paint it, should only be a couple hundred if that
ate lug
88 + 96 broncos, 96 F250
I just yanked the pins, and left the brackets on the fender :toothless
On the tailgate, i took the bracket off, and put the screws back in the holes and painted em black.
Gonna need to do this soon myself.
I've got no problem with putting the bolts back in and calling it good...
BUT...
Where the hell do I put my spare?!?
Anybody come up with a solid way to store a 35 inch spare?
Need something secure enough for muddin and mountain climbing. :rockon
i barley ever had the rear seat in, but what i did was throw a tire iron, a under the tire, put the tire over the center mount for the rear seat, and bungee corded it there, the tire covered the tire iron, and i had a small board and i threw that over the tire. and i covered it with a APB
( All Purpose Blanket :D ) kept it looking clean, and the tire didnt slide around too much
ate lug
Believe it or not, but a 35" tire, laying on its side, will just fit between the tailgate and the rear seat. I currently have it strapped down to a few ublots i put through the bed, but i still want to build a carrier for it like Blown has.
G
No rear seat? Use a 1/2" "J" bolt or screw eye cut to a "J" shape. Hook it around the rear seat clip mount bar in the center of the bed and up through the rim. Crank down 3/4 nut. It works great!
I have my rear seat folded up and the toolbox is strapped forward sandwiching the spare :thumbup ... coupla straps holding the tire from slipping side to side as well
I would also recommend doing what reptilkus has done :thumbup
ate lug
SNIBB said:
i like reptillikuses idea. i think that looks good man :thumbup.
Thanks Man! :D
I dont remember anymore why i originally did that (lazy?), but i think it looks better than having 6 bolt heads sticking out of the fender.
negative creep
bnkrtstk said:
You might be, but your tires aren't. Oh well to each his own, if we ever wheel together you can use mine if needed.:thumbup
thanks:beer
i guess i should clarify. i won't be doing any real wheeling before my next trip home and until i just bought my 35s, i didn't have a fullsize spare. i needed a fullsize spare because i have posi in the rear. i also pay a shitload for AAAs best coverage so i can get towed 100 miles if i have a flat on the road.
either way, my spare is probably going back on when i go home over christmas break since i now have a 35" spare.
1 - 20 of 20 Posts
