Cause I am new, I don't know what Rims are possible for the Bronco_Only 5 Bolts for Ford or maybe also other from Chevi or Dodge?
Thanks
Norbert
It's BTW Not AKA!
Yup, 5x5.5
Older CJs as well as the 5 lug Dodge trucks use the same bolt pattern.
The hole in the center of a factory Dodge wheel is too small to fit over the D44 hub. Aftermarket Dodge wheels will fit. Chev also made some 5 lug 2wd's that are 5 on 5.5 IIRC.
Stay away from newer (97+) Ford wheels. Some may say 5x5.5 but they're acutally something like 5x135mm. Small diffrence, but they won't fit. Just check before you buy them to make sure they are actually 5x5.5
