1 - 12 of 12 Posts
I have sucessfully run Iroks on beadlocked 8" rims which make them about 9" wide. Interco suggest a 10" rim. It is all about running the correct pressure to get them to wear correctly. Take them out behind a local Wal Mart or some place with a good long section of flat concrete, chalk across the tread, run it strait about 50 yards, check them and adjust tire pressure accordingly. I have had good luck with that technic. If you don't run them withthe correct pressure right they will wear in the middle.
It's BTW Not AKA!
But why you would want to no one knows. Tires that wide just look retarded IMO.
Your bronco looks retarded. Those are fighting words as far as I'm concerned. :goodfinge
I ran 35x15 TSl's on my '78 and they saved me quite a few times when I tried going into bottomless mud. I sank to my frame once and the truck pulled through under its own power. The extra floatation makes a HUGE difference.
It's BTW Not AKA!
I didnt say anything about his Bronco. I was reffering to that particular tire size on that wheel. So put down your gloves.
1 - 12 of 12 Posts
