I hope to get a good opinion poll started. I’ve searched the forum but found limited info. Here is the Question, 15" or 17"? :scratchhe 37-12.50 or 39.5-13.50? Radials in either size are without question! 15x10 or 17x9 Bead locks are a strong consideration http://www.trailready.com/[/url] (by Trail Ready). The concern with the 15” 39.5s is sidewall flex & strength:muscle071, A 17” in this size I believe would limit this concern as well as beadlocks with the 15". Cost of coarse is always an issue but….. Now I haven’t mentioned the 37s I put that size out there because, well it was the first size I considered but then looking at the difference in cost between them and the 39.5s… I realize regardless of the strength of the axles the larger the tire the more stress and chance of failure is a factor on any component! I also realize there are many more variables that can be put into this equation! So what does everyone run, again 37" and larger only please!!!:duh Mfg., tire size and rim? back spacing? DD or trail only or both. Bead locks or not. Spacers or not? 5 lug 6 lug, 8 lug, ½ ton, ¾ ton, or 1 ton axles? What kind of performance did u get? what would you do different? do you play in the mud or rocks?:shrug
