I finally went topless this weekend with my 1996 XLT :rockon
http://www.superford.org/getfile.php?id=114715&toggle=fullsize&f=Brake light installed 2.JPG
It took a little hunting for the right tools however I got it off in one piece (and solo no less). Those of you who have the later models (92+) need some special tools to get both the seatbelts and mounting bolts off. I searched the site for the bit sizes and did not see them mentioned so here goes:
T50 Torx Socket (for Seat Belts).
T40 Security Torx Socket (I adapted a drill bit security Torx Head to a 1/4 Socket)
I even purchased the plastic panel fastener removal tool (busted 50% regardless) :shrug
Since I reside in the "Peoples Republic of California" I also had to fab up the third brake light. I used an off the shelf 4 LED light ($10), a piece of lexan (I shaped to the light size) and a "L" bracket.
http://www.superford.org/getfile.php?id=114716&toggle=fullsize&f=Brake Light Fab.JPG
I used the mounting screw as the ground point and an 18 AWG direct burial wire (overkill but all I had) to complete the circuit.
http://www.superford.org/getfile.php?id=114717&toggle=fullsize&f=Brake Light Wiring.JPG
I ran the wire into the paneling on the driver's side and tapped into the solid green wire at the rail to top connection.
http://www.superford.org/getfile.php?id=114714&toggle=fullsize&f=Brake Light Connect.JPG
I made this removable so I can still but the top back on. Hope this helps give you guys ideas........
