1 - 10 of 10 Posts
while towing a a u-haul tralor i expereinced a weird jerking and the tach started jumping any idea's it was there biggest covered tralor.:shrug :shrug
aka: kemicalburns
we need more info here . like year, engine/tranny combo. size tires your running things like that. other wise we have no idea what bronco your talking about.
later
aka: kemicalburns
well running a tire thats bigger then stock doesnt help with those high gears. you maybe having tranny issues. take it down to an auto parts store and have them pull some codes its free. when was the last time your rig had a tune up, might be time for plugs,wires,cap, rotor and reset/check timing. your not driving in OD when your pulling are you. it should be turned off.
just did total tune-up including new msd ciol also have been expereincing at high rpm or when you get on it the tach drops a couple rpm's.if the tranny was slipping wouldn't the rpm's go up ?
But what does mine say?
Just like kemicalburns said... go have the codes read. I think it's your VSS, but you can never be sure until you have it checked.
aka: kemicalburns
you pulling with the OD off? maybe its time for a tune up
irwin said:
what is vss?no codes i have a code reader shows everything is cool.
vss stands for vehicle speed sensor. It's a little electrical device that is on the top of your rear differential...
my bronco started bucking and jumping one time when i was towing a heavy load too... i figured it was the 8 tons of peanuts i was hooked to :toothless
1 - 10 of 10 Posts
