1 - 12 of 12 Posts
When i get on it the rpm's go down for a couple of seconds sound like throttle positioning sencor??already did total tune-up checked cat's replaced o2 sencer checked feul pressure and bought a new ciol checked timing
Are those REAL?!?!
Before you start replacing everything systematically, if you have the code checker, run the diagnostics and see what it spits out. Then, also look for a vacuum leak... and also, check all your air intake connections...
Fireguy50 said:
what do you drive? :twak
do you need more info than a 94 bronco
OUT OF BUSINESS / M.I.A.
First, I never read 94 Bronco in this thread untill you said it.
Second, yes I need more. Engine? Trans? Mods done? What was the fuel pressue when checked?
Haven't chagred anybody for internet help yet, and I ain't pulling teeth, so help me help you.
1994/ 351/e4od/32'tires/ 3.55 gears
It might be the pickup coil.
i beleive it was 42 psi the feul pressure more than it needed to be/it has doing it for a long time now the tune-up made it seem like it did it less though there no ryme or reason to when it does it(hot or cold) that i have noticed.i have a new ciol.the feul pump whines though but the pressure was cool.hold on irwin it deosn't do it if your reving in park just while driving and getting on it.have your herd of feul pumps having promblems under a driving load???? :shrug sorry always forget to put the specifics :twak k&n drop in msd ciol 3' cat back exhaust
Mine is doing the same.If it wasnt EFI,I would say it sounds like a carb accelerator pump is bad...haha. Replaced TPS(It was bad though,no voltage).Doing same. LONEWOLF
Are those REAL?!?!
Sounds like a small vaccuum leak to me... mine turned out to be the vaccuum hose that runs to the fuel pressuure regulator.... was an ever so slight couldn't see it unless you bent the crap out of it, crack in the hose....
Tom
So what was the solution????? I have a similar problem, slight hesitation on acceleration through 1700 rpm, full tune up completed and replaced the TPS.
1 - 12 of 12 Posts
