1 - 16 of 16 Posts
hate starting a new thread for such a simple little question, but I couldn't seem to find an answer. I was wondering why no one uses the stock 78-79 track bar bracket. Or has some one used it? I am going with 4" 78-79 coils when I so my sas.
Thanks all
One reason is that the stock mount is in single shear vs. most aftermarket or home-made mounts are in double shear. Not saying that you couldn't do it and make it work, but it's just easier to make a switch while you have the axle out.
There are some people that went with a single shear panhard bar do to size constraints but they beefed the mount up.
They are very common on cracking the frame. Very bad design on Ford's part there. The other thing is I don't believe it will fit unless you're using a custom track bar. With the TTB frame the upper mount needs to be more under the frame rail while the pre-1980 bracket puts it on the side of the frame.
Former owner of Shadofax
yes.
but as Alex mentions, this assumes we are talking upper frame mount.
Not to mention if you have any fab ability it's pretty easy to come up with something way stronger.
Discussion Starter · #12 ·
Maybe :popc1:
Hey ogeechee,
Thanks for the picks I think I could through that together in a few minutes. Also from your pick it looks like you are running 4" of lift and stock ttb buckets is that the case? If so hom much lift did you achieve. I am basically going to run the same setup if that is the case. Oh one more thing it looks like from the pic that you trussed that bracket across to the engine cross member is that the case?
Thanks
Land
Yep. That's what I did...
6" 78/79 Skyjacker coils
78/79 coil buckets
probably 7-7.5"
This has been quoted 3 times already in this thread. Below is number 4...
Ogeechee 4x4 said:
...braced it to the engine crossmember...
Check out Mike's (Meixter) track bar mount in his SAS file on Supermotors. If you're sourcing parts from 78/79, he used a upper shock mount/ trac bar mount also, cut to fit for position and height. Great contact surface for welding and hell for stout material.
Discussion Starter · #15 ·
What is that he used for his trackbar? I have seen it befor but can't put my finger on it.
1 - 16 of 16 Posts
