1 - 3 of 3 Posts
Im not sure if this is the right section but,
I filed the report last night but it could have been stolen earlier.
It is a tandem (dual) axle trailer with 1 axle with brakes and the other without. The axles are from a trailer home and take 14.5 inch tires!!! These are not so common so this will help id the trailer. Also it was in pretty bad shape, 2 tires were down to the steel and they were much smaller which caused one axle to sit aginst the frame and the other to almost ride in the air. It was mostly a burgendy type color but had blue paint chips all over it. One crappy ramp is missing. It has NO id markings, as far as i know it was hommade and it DID NOT have a tag, there was no decking in the middle and the decking it did have was heavy duty steel mesh, it looks like the lock (which i found) was sheard off with pretty good force (crowbar?). I am keeping just a couple of facts to myself to help id it if it is found but any information should be directed to me at 770-855-3946. Pics if I can find some later. thanks for any help.
Some assembly required!
Sorry to hear about you trailer, but just so you know, trailers built on mobile home axles are extremely common around here. At least a third of the trailers I see are built that way, so that might not be the best thing to look for. Also, you didn't mention where you are, might help people to know what area to look in. Good luck finding it.
1 - 3 of 3 Posts
