1 - 4 of 4 Posts
3 wheeler
I have a trailer that I use that it comprised of two mobile home axles. The tires are so far out of balance that it makes the trailer simmy and shake when it is unloaded.
I don't know if you can balance mobile home trailer tires but i wouldn't want to pay to have it done anyways. My thought was could I use the plastic/rubber BB's that Andy351 used in his drug smuggling write up to balance the tires?
As long as your tires aren't tubed, give it a shot. And while the tires are broken off the bead, have them turn the tires 180º on the wheel
Banned
It might reduce their radial runout, but without measuring first, it's just as likely to make it worse. Why not just get them balanced? It'd probably cost less than the time, gas, & $ for these BBs, and you'd KNOW then.
1 - 4 of 4 Posts
