I've got 8 wires out the back of my 1990 XLT for the factory trailer wiring. 6 of them are hooked up to a standard 7-pin RV connector, leaving 2 wires disconnected. I know some, but what do the other wires go to ???
White = Ground Wire
Yellow = Left Turn Signal
Brown/White = Tail Lights
Orange = ???????? ; connected to the "auxiliary" pin
Green = Right Turn Signal
Blue = ???????? ; connected to the "electric brakes" pin
Then the two wires not connected are Red/Yellow, and Red/Green ... What do these two wires go to as well ????????
I ordered a vacuum/wiring book, but it hasn't arrived yet, so any help is greatly appreciated. Thanks for looking.
yo;
here ya go;
Trailer Harness Wiring Colors TSB 89-14-17 for 90 Bronco & F Series
Source: by miesk5
Publication Date: JULY 14, 1989
LIGHT TRUCK: 1990 BRONCO, F-150, F-250, F-350
ISSUE: Trailer tow wire harness color codes have been revised to be compatible with SAE color code standards. When hooking up a vehicle to a trailer that has been wired according to the SAE standard, the wire color/circuits will match.
ACTION: Refer to the following Circuit Color Code Chart for the correct color/circuit usage.
CIRCUIT COLOR CODE CHART
CIRCUIT FUNCTION - OLD COLOR* - SAE COLOR*
Trailer LH Turn/Stop - LG/O - Y
Trailer RH Turn/Stop - O/LB - DG
Trailer Brake Lamp From Controller - R/LG - R/LG
Trailer Electric Brakes Solenoid - BL/BR - DB
Trailer Back Up - BK/PK - R/Y
Trailer Ground - W - W
Trailer Running/Tail - W/R - BR/W
Trailer Power (Battery Charge) - Y - O
Trailer Brake Control Feed - R - R
Color Key - Color Abbreviations
BL-Blue
BK-Black
BR-Brown
DB-Dark Blue
DG-Dark Green
LB-Light Blue
LG-Light Green
O-Orange
P-Pink
R-Red
W-White
Y-Yellow
Thanks man, but I'm not familiar with what a "Trailer Brake Lamp From Controller" is? Any insight?
Also, according to what you have listed, then I should connect the Red/Yellow wire up to the center pin(s) of the 7-pin RV connector on my Bronco ... in the event I ever tow something with reverse/back-up lights on it?
Thanks again, yo. :thumbup
yo W
I'd leave that center Pin empty since it's just another thAng to short or grnd out, (Pin #1 in the 96 Bronco Diagram below, but Ford musta changed colors by 96 from R/Y to (BK/LB)
This is from a 96 Fod Manual;
In case Image dies not appear here:
http://www.thedieselstop.com/faq/9497faq/maint/stj/images/k23203a.gif
http://www.thedieselstop.com/faq/9497faq/maint/stj/stji1007.htm
"Trailer Brake Lamp From Controller" it's a little module that supplies power from da Bronco to the trailer's electric brakes.
It's shown in this Trailer & Camper Wiring Diagrams for 94 & 96 Trucks @ bottom left
Source: by Ford via Steve83
