1 - 20 of 21 Posts
huh
Trailer Wiring? How do i check it before picking up a trailer..
Im trying to figure out if the setup i have works.. ive never towed with it so i dont know...
Here are some pics.. how can i test it..
this is whats on the bumper..
this is the plug i used on the other bronco to tow.
this is the other side
got this tool... tell me what to poke
the plug goes into the socket ok but im not sure if its the right kind. the guy says the trailer has a 4 wire flat plug.. that thing i have has 8 but im assuming you can use the bottom or top seperate.. any help is appreciated
Re: Trailer Wiring? How do i check it before picking up a trailer..
ur eye. :toothless
go to any parts pit and pick up the 4 pin flat one.
it has directions which color wires go into the trucks harness. all you need is running lights, signals, and brake lights.
Crazed said:
He probably wants trailer brake wires set up too...:shrug
if the guy said that the trailer has a flat 4 wire plug, then the trailer doesn't have brakes...
that's gonna be a lot of weight for your truck to stop...
:brownbag
OUT OF BUSINESS / M.I.A.
White - Ground
Yellow - Left Turn
Green - Right Turn
Red - Brake
Black - Marker / clearence lights
Brown - Tail lights
Blue - Aux circuit
Black and Brown might be the same thing
Blue might be blank
Make sure the White is ground should be the center pin
So stick one end of the tester in the center pin.
Stick the other probe of that tester on the other colored pins
The light should come on when you turn on the above features
huh
:brownbag
its got brakes.. just not connected yet. The guy bought a toy hauler while he was building the trailer im getting from him. just need to get it home.. ill mess with the wires when i get home..
oh and thanks ryan..
You just need to get it home? Psssh throw a kid on the back with a flashlite and just yell out the window what yer doing :)
I just pulled a trailer from Malibu to Chatsworth with no lites and no problems :p
The adaptor you have will work fine for a 4 flat connection. You have 2 options with that adaptor first 4 flat and the other 3 male and 1 female, normal for most tralers. As far as poking with the testar just put in your adaptor and have someone press the brakes check the 4 flat side all four connections until you get a light, blinkers one for left and one for right, and running lights.
Clear as mud:toothless
huh
Discussion Starter #11
i got under the limo to get a good ground and to my surprise i found 2 more plugs back there.. one was a simple 4 flat and the other was a setup with 8 like whats on the end of my adapter.. i checked it and it worked.. so im setup for a couple of different plugs and didnt know about it..
:thumbup
Are you going to rewire the trailer for brakes when you get it?
:brownbag
just because a trailer has a 4 pin plug does not mean it does not have brakes.
alot of trailers have surge brakes which do not need any electric controls for them.
huh
Discussion Starter #16
welndmn said:
:flipoff2:
http://www.wt4wheeling.com/tech/7wire.htm
DO you also have a control uint? If not you need to get one
hey mark... i saw those diagrams and info on pirate and they went off about how wrong they were..
is the control unit that squeeze thing up front that turns on the brake lights.. ? if so, then yes i have one..
Well Done Man!
Mine are dead right :) (wired a ton of trailers) The guy on Pirate used my table and then tried to inport the info and ****ed it up. (sereves him right)
When you squeese the unit, no the brake lights should not turn on
huh
Discussion Starter #19
they do. i use it when people are tailgating me.. slows them down real fast..
1 - 20 of 21 Posts
