1 - 10 of 10 Posts
My tranny cooler is located on the engine side of the radiator. Should it be moved? We are having overheating/fluid boiling over. I am asking because today we have to replace a cooler line that is bent almost 90 degrees and restricting flow.
MARBLE GARGLER!
The trans cooler should be infront of everything ! It should br the first thing to get the cool air.
isnt that your problem right there? if it aint circulatin, its bound to overheat... but everyone Ive ever seen is in front of radiator...
It needs to be in front of the radiator. If you leave it behind the rad it will continue to not do very much. All the air on the backside of the rad is hot and it needs cool air to help your trans.
sorry i havent been online to reply. The cooler is between the radiator and the fan. There is enough clearance for it to be mounted. We purchased it a few months ago and didn't realize the mechanic that did all the work-including tranny rebuild wasn't very good. I just wanted to make sure on the location because it didn't seem right. We are rebuilding this weekend and want to do it the right way.
MARBLE GARGLER!
Seattle, That's the same cooler and same set-up that I got, I don't think towing a trailer uphill could build too much heat with that unit installed-
This weekend will be moving my cooler so that it is no longer a tranny heater. I guess it would be a good spot if you lived in Antartica. My lines are rubber and metal that have been pieced together and will be replaced. Also putting new front pump seal on to get rid of the leak and buy some time before we have to rebuild.
1 - 10 of 10 Posts
