1 - 2 of 2 Posts
i am replaceing the motor in my F-150. when i removed the shifter off my 4-spd i found metal shavings and a chunk out of one of the gears. so im wondering if i should rebuild it or just replace it with the c6 i already have the only problem is that the c6 is 2wd. what would your advice be?
Nvr Been Bnnd
try and find a 4 speed you can trade for. I wouldnt want to go converting a manual to auto and then loose 4wd too! unless you have to have the truck right away... Or call around some OLD shops that rebuild manual trannys and ask if theyll take the c-6 in on trade!:beer
1 - 2 of 2 Posts
