1 - 2 of 2 Posts
i have an 81 bronco with a 351 and a c6 the tranny went out .. I got another running driving bronco same year same eng and trans for parts shifted good.. got it home both trannys out put the one from the parts bronco in and now it dont work ive narrowed it down to the fact that there is no fluid pumping i pulled the tranny line off nothing the tranny worked fine in the parts bronco nothing in this one open for ideals
Discussion Starter #2
i bet ur right i left the convertor bolted to the fly wheel when i swapped trannys ill see when i get it apart is there anything else i should look at in the tranny if it did break the pump like metal chunks inside or do i need to just replace the pump and make sure the convertor is all the way seated
1 - 2 of 2 Posts
