i have a stock 1994 bronco with 351w my tranny keeps on slippin it shifts really hard it jurks .sometimes i have to remove my foot from the gas so that it can switch gears. the revs go up like crazy. it does this sometimes not all the time and i notice when it does this the cruise control dont work. any help would be appreciated. ive fixed the tranny two times and the rear axle twice because of the problem and looking on selling please help
Neutral positing switch, or sometimes it calls neutral safety switch.
On a 94 its called a MLPS, and is found at about the mid point of the trans on the left side. It is a well known weak point on E4OD's.
What I would do in your case is to check for any codes before I do anything else.
Is your speedo working correctly?
Is the OD Off indicator light flashing at all?
Satyr of the Midwest
There's a thread over in Emergency Help about this issue right now. I posted a diagnostic routine there, too. Again, sorry for the huge image. :D
Doh, NM.. mis read.
