1 - 15 of 15 Posts
So im getting my rebuilt trans tomorrow, and i need to get some new transmission oil, should i get castrol dex/merc ? or should i get something else?
remember i need to get like 16 quarts
thanks
1996 EB 5.8L, E4OD, 2.5" RC Lift, 33" tires, 4.11 gears
thanks
I use mercon V in my e4od and the valvoline full synthetic transfer case fluid in the bw1356. I think there is a thread around here discussing the valvoline transfer case fluid that may be worth a search and read.
im tempted to use valvoline transfer case fluid, let me see if i can check out that thread
Here is a link that talks about the different fluids for Ford TCs.
Dexron III is compatible to original fluid since Ford doesn't offer it anymore. No need to go Motorcraft if you don't feel like it.
Moderator and Scrounger Extraordinaire
I run carquest generic multi-atf in my 96 c6. I bought a 5 gallon bucket when i was going through a gallon every couple weeks. Finlay found a broken part on the c6 case.
TTB FTW
dont use mercon V in a transfer case. it would be fine for the transmission though. I would just run dex/merc. like mobil d/m. summit has cases of 6 quarts for $20.
mercon V will not harm the t-case. Mercon V will work for anything that originally called for mercon fluid
1 - 15 of 15 Posts
