Our 86 bronco 4x4 trans can only go into reverse so assume the trans is bad.. fluid looks very dark.
What trans options do we have for swapping?
Thank you.
Thank you.
Sorry should have been more specific. Yes auto. I have to confirm if c6. I was looking at our local junkyards and noticed things like a 94 ecoline with a 5.8 with 3speed auto trans. And a 93 ecoline with a 5.8 w/ 4speed (maybe 4speed?, think could be typo because says 3spd too). There is a lack of 5.8 fords at this time there.I assume it’s a C6 automatic in it now, you could swap in a AOD, a MO5RD, ZF5, SM456(?). All are going to need a different transmission cross member and drive shafts, plenty of information here on transmission swaps.
You'd need a C6 with a small block Ford bellhousing, so one that was previously mated to a 302, 351, or 300 straight 6.What other ford vehicles would have the same trans?
Found a c6 with 20k but was mated to a 460, i guess this would not work?
From what ive read,this requires tearing into the trans to swap the 4wd shaft into? Is that correct?The van transmission would be 2 wheel drive, so a conversion would need to be done
Yup. The output shaft is the very first thing to go in and last to come out of the trans. So the entire geartrain must come out.From what ive read,this requires tearing into the trans to swap the 4wd shaft into? Is that correct?
So i guess my question now would be since i cannot find a 4wd c6 trans around here, would it make sense to just rebuild the one we have? If id have to tear into the 2wd trans (that i cannot confirm even works,just a fellows word) to replace the shaft, kind of seems like a gamble to begin with plus work.. ive read the c6 is not too terribly complicated and viewed a video of tear down..Yup. The output shaft is the very first thing to go in and last to come out of the trans. So the entire geartrain must come out.
Yes, skip the 2wd stuff and just rebuild yours. A guy over on the FordSix.com forums by the name of HitmanX could walk you step by step through it. Idk squat about building an automatic.So i guess my question now would be since i cannot find a 4wd c6 trans around here, would it make sense to just rebuild the one we have? If id have to tear into the 2wd trans (that i cannot confirm even works,just a fellows word) to replace the shaft, kind of seems like a gamble to begin with plus work.. ive read the c6 is not too terribly complicated and viewed a video of tear down..
he could also use a e4od or 4r70w. would need the right ecm or a stand alone controller. the e4od i think shares size with a c6 so if he did go that route he wouldnt need to change crossmembers or driveshafts. just need a 90-91 ecm and a overdrive lockout switch mounted somewhere and maybe some wiring.I assume it’s a C6 automatic in it now, you could swap in a AOD, a MO5RD, ZF5, SM456(?). All are going to need a different transmission cross member and drive shafts, plenty of information here on transmission swaps.
yeah you would basically have to rebuild it to convert it.From what ive read,this requires tearing into the trans to swap the 4wd shaft into? Is that correct?
E4OD is longer, however those parts are easier to come by then the C6 stuff. I know this having went the other way e4od to c6 in my '92.he could also use a e4od or 4r70w. would need the right ecm or a stand alone controller. the e4od i think shares size with a c6 so if he did go that route he wouldnt need to change crossmembers or driveshafts. just need a 90-91 ecm and a overdrive lockout switch mounted somewhere and maybe some wiring.
i see that. my bad. so the c6 is actually about 21 inches and the aod is 22. so will a aod or 4r70w swap without mods i wonder? i was thinking one of the trans did but for some reason i thought it was the e4od. i know the 4r70w and the aod are same in size but now im curious as to the c6 vs those too. ive never fooled with a c6 really. if i had one id rip it out for some od trans.E4OD is longer, however those parts are easier to come by then the C6 stuff. I know this having went the other way e4od to c6 in my '92.
The C6 is the shortest of all of the transmissions, so going to any other transmission requires a different cross member and new drive shafts.i see that. my bad. so the c6 is actually about 21 inches and the aod is 22. so will a aod or 4r70w swap without mods i wonder? i was thinking one of the trans did but for some reason i thought it was the e4od. i know the 4r70w and the aod are same in size but now im curious as to the c6 vs those too. ive never fooled with a c6 really. if i had one id rip it out for some od trans.
