94 Eddie Bauer Bronco, 5.8l , E4OD , electric shift, warn manual locking hubs. BFG 31/150s
94 Bronco Eddie Bauer 5.8 with E4OD trans. Trans was rebuilt a thousand miles ago and i drove it with absolutely no problems. During the last trip i noticed Radio went out, dash gauges stopped and windows would roll down. I stopped at a redlight and the truck died. I jumped it off and it drove home but only in 1 or 2 and it needed lots of RPMs to get going. I replaced the battery and altenator and now it will not move unless it is in 1st and really revving the motor.
I found some wires that may have burned against the Catalytic converter but i dont see bare wires. Fluid level is good.
Thoughts ideas on where to start?
Thanks in advance.
I havent pulled any codes. The wires are the ones that pass over from the shifter linkage connector to the passenger side.
Thanks
Yo BroncoTOP,
Welcome !
As advised, try a Self Test for Diagnostic Trouble Codes by my pal, BroncoJoe19 @ Code Reader.....
The engine temperature must be greater than 50° F for the Key On Engine Off (KOEO) Self-Test and greater than 180° F for the Key On Engine Running (KOER) Self-Test. Run it around to heat the engine up and shift thru all gears including Reverse. Make sure A/C is off and transmission is in Park (automatic); or in Neutral for a Manual and; release clutch. Then turn off engine, all accessories/lights (close driver's door) , etc.
Do KOEO test First. Post Code(s) here according to KOEO and KOER.
A helper can assist you by counting the codes. Some use their smart phones to record them.
BEWARE OF FAN, BELTS, PULLEYS, HOT HOSES, IGNITION HIGH TENSION WIRES, AND ENGINE COMPONENTS⚠
Or ask local mom and dad parts stores if they will test it for you.
Or purchase a coder reader such as Equus 3145 Innova OBD I Code Reader for Ford EEC IV Engines at Walmart & most parts stores.
E4OD Transmission Control Indicator Light (TCIL) is a LED and overdrive on/off switch at end of the Transmission shifter stalk; flashing OD light is an indication of a transmission related trouble code in the Powertrain Control Module (PCM).
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view due to scammers who preyed on our members.).
Our Forum FAQs includes for example, How To Upload Images To Posts, How to Use Search, How To Save (Bookmark) Threads Or Posts & more tips!
BabaLooey's Favorite FSB Links (lots and lots of tech links) ... includes such as, "Tailgate Window repair & troublehooting.
1994 Bronco Brochure, Partial; Cover & Page 3; plus pics of EDDIE BAUER model accessories.
by BigRob at 1994 Ford Bronco Bronco Accessories pictures, videos, and sounds | SuperMotors.net
Try to find time to participate in our next Full-Size of the Quarter & Full-Size of the Year Contests @ Voting
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Al
