1 - 4 of 4 Posts
I have a 86. with a 351 and a c6. will a c6 bigblock fit were the normal one goes. will the c6 bigblock work with the transfercase i have? please some help can be a life saver. also can a torque converter make my truck sound like a banging rod or knocking if bad?
Ex Navy Nuke
If you want to use a big block C-6 then you'd need to swap the engine out for a big block also. If that's what you plan on doing then yes it will fit but you can't connect a big block C-6 to a 351W(SBF).
FSB warrior
But on the T case end it doesnt matter as long as its from a ford it'll have a 6 bolt pattern and the correct # of splines
1 - 4 of 4 Posts
