i have a 91 bronco with a man. transfer case the case has gone bad i also
have a good case from a 90 bronco however the 90 case is electric shift does anyone know if it is possible to convert the electric case to man. shift or should i just attempt to hook up the wiring in the truck to be able to use the electric case as is in the man. truck
thanks for any help
Ted
How hard would it be to take the output shaft off the electric Tcase and put it in the manual. I too have 2 transfer cases sitting around.
shibby
Not hard. Basic tools are a socket for the rear yoke, torx bit for the case bolts, good pair of c-clip pliers. I've got two cases disassembled on my workbench, took about 20 mins per t-case to disassemble.
Cool. Finnally have some time to attempt this.
