1 - 18 of 18 Posts
So i decided im going to buy a second hand transfer and rebuild it over time, I need 2 things to get recomened by you guys
1. best place/deal to find the bearings/seals and oil pump kit (chain i dont need since its already 100$ just for the chain)
2. i need some one to help me do the oil pump retainer modification to weld on a rod, i dont have any friends with a welder and if i do non have a experience doing so on that metal
Thanks for the help guys and gals :)
Addicted to Junk
Addicted to Junk
So guys i got this beauty ish haha came off a 89-91 ish bronco, i know this cause it has the mechanical speedo attached to the back
i think the bearings are fine, and it looks like they changed the seals! but i might need some help with that
what should i look for? i know the wear on the pump retainer
View attachment 177761 View attachment 177762 View attachment 177763
The only seal that looks new is the RTV between the case halves... which also looks like way too much... when you open it up I would look for RTV in the chains and sprockets, as well as stuck in bearings... none of the external seals look to have been replaced.
Charlie don't surf..
'92 Ford Bronco XLT
The tail shaft housing from your bronco will easily swap over to the one you bought so you don't have to worry about mechanical speedo. It's been a while since I tore into a transfer case, and to be honest there isn't a lot that can go wrong with them. definitely check the oil pump retainer and do the fix, it's almost certainly going to show wear. you'll also want to check the chain for slack..most of the time they're ok and then look around for any metal shavings in the case. good luck.
Discussion Starter · #10 ·
thanks man! but the tail housing has a aditional plug for the motor, can i just unplug that? or is it needed?
Discussion Starter · #11 ·
actually i took the motor off and looked at the shaft and they replaced it with national seal so they have been worked on
'92 Ford Bronco XLT
Just to clarify, is you existing case electric or manual?? I know it was gutted..
Discussion Starter · #13 ·
the one on the truck is electric
and the one i gor is electric but has this plug going next to the speedo wheel
The transfer case to transmission seal hasn’t been replaced, nor the output shaft seals... I can clearly see in the pictures you provided where they have very old grease... also the sealant between the case halves should not be be visible... as it clearly is... hence I said I would definitely crack the case open to make sure no sealant has broken loose... if the sealant has broken loose it can get caught in the pump... which is why your case was more than likely gutted in the first place.
'92 Ford Bronco XLT
got it. I would have to see the two side by side, does the one in your truck still have the motor in it? If so, it seems to me like you should just be able to swap over the motor and tailshaft housing to the new case and call it a day..unless I'm missing something.
Addicted to Junk
Bronco Driver magazine has a great article on rebuilding the 1356 in a 2007 printing with a pink early bronco on the cover. Its sitting in my 'bathroom reading material' lol.
Reactions: jermil01
Discussion Starter · #17 ·
yup its missing the the motor and any kind of connector on the transfer
Discussion Starter · #18 ·
HAHAHAHAH!!!! i need it!
1 - 18 of 18 Posts
