1 - 4 of 4 Posts
I can't get my Bronco into 4WD. I used the 4WD on Tuesday night I parked the truck removed it from 4WD then got up the next morning and can't get it back into 4WD. I don't hear any clicking, I checked the fuse and main switch no problem. Any ideas?
if the botton was working then you should hear a clicking sound coming from the passenger side of the dash so your botton might be dead or dieing cheap replacement ~$30 from ford. You might also want to try tapping on the 4x4 acuator motor with a wrench and see if that works replacement of that costs ~$170. Down the road you might want to switch to manual hubs and transfer case.
you can check the 4wd control module pretty easy. Pop off the right kick panel and you can see the 4wd control module.
Disconnect five-wire and eight wire connectors from electronic control module.
Turn ignition switch to the RUN position.
Activate the self test switch and note result:
NOTE: The self test switch and indicator light is located on the Electronic Control Module.
A FLASHING INDICATOR LAMP, (approximately one flash per second), indicates control module is functioning properly.
A STEADY INDICATOR LIGHT, indicates that control module is inoperative and must be replaced
LONEWOLF
1 - 4 of 4 Posts
