1 - 11 of 11 Posts
So my bronco won't catch any gear at all not even park then next day worked fine and shut it off after test run and nothing again and it wants to grind when I try to put it in park .but also when it does work it's tits shits great when dropes in gear you know it imean just the way you want it to help
Well? Without year engine transmission info you can’t get much help.
89 v8 efi
Sounds like the tcase is slipping in and out of neutral. Electric or manual tcase?
Yo Christeraz,
Welcome!
As XDAILY advised; "When the transfer case is in the N (Neutral) position, the engine and transmission are disconnected from the rest of the driveline.
Therefore, the vehicle is free to roll even if the automatic transmission is in P (Park) or the manual transmission is in gear."
Identify your transmission from attached depiction.
150294
Should be AOD or C6.
AOD is used in 1989 5.0
C6 is used in 1989 5.8
See attached AOD & C6 Basic troubleshooting guides:
150296
150295
For C6, check vacuum at modulator. Modulator is on the rear of the transmission, passenger side.
Pull the vacuum line off the mod. If fluid comes out of the vacuum line your modulator is no good.
Check vacuum line to modulator from engine intake manifold source.
See attached C6 troubleshooting:
150297
Also fyi:
1356 Manual Shift, No Movement or Neutral Position Tip/Saver Spacer & pic; "...Many 1987-1995 Ford F series 4x4 trucks and full size Bronco owners with 1356 manual shift transfer cases commonly complain of a "no movement" or an occasional neutral condition. This condition is usually caused by the linkage wearing the transfer case at its point of contact (1356 manual shift models only). Sonnax offers a case saver spacer 36605-01. This case saver spacer goes between the shift selector cam and the case and requires no special tools to install. The spacer moves the cam closer to the shift fork, thus preventing and/or eliminating: 1) one or both shift forks from becoming disengaged from the shift cam, 2) "slop"from the linkage caused by a worn linkage bore in front case half. This item is a specific size/thickness not commonly found in ordinary flat washers. This repair is quick, easy and a lot less expensive than repairing or replacing the case. Model: 36605-01..."
Source: by transmichigan.com
Make your own if this is the issue.
89 v8 efi
5.8 it's the manual one no motor and the vacuum pump on the passenger side did not have fluid in nor coming out of it Ben having vacuum issues to it also had started shifted the next day turn it off put me o2 censor in and start it then nothing agia no gears at
The other thing I'm now noticing is even when I put it into four-wheel drive I have to push the buttons on the dash and normally I would hear my hubs lock and they're doing absolutely nothing at all
This is a key post.
Your transmission is working because the output shaft is spinning. This is noted because of the grinding in park. This means 100% your transfer case is at fault because it's not able to hold a brake to the output shaft nor transfer the output to the rear axle. Repair or replace your transfer case.
This is a key post.
like maybe one of the shift forks may be stuck ?, the other thing that keeps coming up in all my research
The only way to find out is to open it up. Common problem is the pump spins inside the case then the transfer case grenades. But I guarantee that the transfer case is the fault of your truck.
If the transmission was at fault, the output shaft wouldn't be turning and you wouldn't hear the grinding of the park pawl against the park gear when placing back into park. The output shaft is where the park gear is located.
1 - 11 of 11 Posts
