what type of fluid is in my transmission cooling lines that go to my radiator looks like some type of oil but i cant seem to find it in my manual ive been looking.
Thx.
1995 5.0L V8 auto trans,
The transmission takes transmission fluid. The transfer case also takes transmission fluid but mercon only or ford spec transfer case atf.
Yo Tyler,
Welcome!
Following by Ford: " ...
Motorcraft Mercon® Multi-Purpose Automatic Transmission Fluid Ford XT-2-QDX or equivalent meeting Ford Specification ESP-M2C166-H​
Transmission Type​
Liters​
Quarts​
14.8​
15.7​
E4OD (4x4) Using old style cork transmission fluid pan gasket​
15.3​
16.2​
E4OD (4x4) Using new style elastomeric transmission fluid pan gasket​
15.5​
16.4​
Approximate capacity includes transmission fluid cooler and transmission fluid cooler tubes. Fluid level indicator (7A020) should be used to determine actual fluid requirement and fluid specifications. Check level at operating temperature. DO NOT OVERFILL. An additional 0.3L (0.3 quart) is required if vehicle has an auxiliary transmission fluid cooler."
See if cooler is on driver side of radiator;
159727
ItemPart NumberDescription
17A095Transmission Fluid Cooler
28005Radiator
37A031Fluid Cooler Tube
47D273Fluid Tube Connector
5372223-S101C-Clip
67N291Transmission Fluid Cooler Line Clip
77A030Fluid Cooler Inlet Tube
8Connector (Part of 7000)
97000Automatic Transmission
10376240-SClamp
11N809635-S165AHose
127F113Inlet Tube
137F112Outlet Tube
ATighten to 23.3-31.7 Nm
(17-23.4 Lb-Ft)
BTighten to 3.1-4.3 Nm
(27.4-38 Lb-In)
CTighten to 10-14 Nm
(7.4-10.3 Lb-Ft)
ASAP⚠, find out if speed control, if equipped, recall work completed by dealership. Call local dealer or register and view status @ Welcome to Ford Owner | Official Ford Owner Site; or @ Recalls Look-up by VIN (Vehicle Identification Number) ... have VIN ready.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
Register with VIN to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site
1995 Bronco Dealer Brochure
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 non-padded posts required to participate, due to scammers who preyed on our members).
Our Forum FAQs includes for example, How to Use Search, post pics and more tips!
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
... Includes such as, How do I fix my back window?
➡ See our Full-Size of the Quarter & Full-Size of the Year Contests @ Voting
Al
