1 - 4 of 4 Posts
Looks like it's just missing the o-ring. :scratchhe
It doesn't go into the pan, rather fits snug into the hole. Held in place by a bell housing bolt.
if i remember correctly, you are missing the oring that seals the tube to the trans. As for the gunk its probably friction material from the clutches in the trans. If you have a ton of miles on the truck its normal. Just make sure you use the correct trans fluid for your transmission or you will do more damage then you think. Please please do not just put in any "multi" trans fluid. It will be costly in the long run.
Alright, I picked up an o-ring for it and now I just have to clean the pan, get the gasket and filter, put it all back together and hopefully it will be done leaking.
1 - 4 of 4 Posts
