1 - 10 of 10 Posts
Wow, it is pretty rare to see the inside of a trans pan that dirty. How many miles and how did it shift prior?
I would drain the torque converter with it looking that dirty.
Looks like a lot of clutch pieces laying in there. That sucks man, they aren't cheap to have rebuilt.
While its out though, pick up a 4R100 pan, it has a drain plug and has dimples in the bottom of the pan to hold the filter in place. Or you can get a filter clip for $6.
yo Coach,
For a reman job, Get a price locally, then check out
Remanufactured Transmissions & Engines - Motorcraft® Brand, Broncos & all Ford vehicles 19.38 MB pdf
Source: by fordinstallersupport.com @ http://www.fordinstallersupport.com/files/catalogs/ptm200.pdf
Remanufactured Transmissions & Engines - Dual Brand, Broncos & all Ford vehicles 35.29 MB pdf
Source: by fordinstallersupport.com @ http://www.fordinstallersupport.com/files/catalogs/ptf200.pdf
get some estimates from the Distributors & Ford; Ford has a good guarantee and the Qual is up there. And the Ford reman trannys/engines do not need to be installed by a Ford Dealer
Look at this Excerpt;
"...Ford and Motorcraft Remanufactured Transmissions and Gas Engines
Ford Motor Company, The American Road, Dearborn, MI 48121 (“Ford”) provides the following Limited Warranty on Ford and Motorcraft Remanufactured
Transmissions and Gas Engines to Ford, Lincoln and Mercury Dealers (each being a “Dealer”) or general Installers (each being an “Installer”). This Limited Warranty provides that Ford will credit the Dealer or Installer for repairing or replacing, at Ford’s option, any Ford or Motorcraft Remanufactured Transmission or Gas Engine sold by Ford that is found to be defective in factory-supplied material or workmanship subject to the following terms, conditions and limitations:
Retail Customers: To obtain warranty service, please return your vehicle to any Ford, Lincoln or Mercury Dealership or return to the Installer who
originally installed the Ford or Motorcraft Engine or Transmission Assembly in your vehicle. Please have your original dated receipt for installation date verification.
Complete Gas Engine Long Block Assemblies (6006/6V012) and Transmission Assemblies (7000/7V000/7003)
• 36 months or 36,000 miles from warranty start date, whichever occurs first. Ford will cover 100% of all parts and labor at approved warranty reimbursement rates
• If installed by a Dealer, reasonable towing charges (up to 35 miles or to the nearest Dealer) are covered only if the vehicle is not covered under
another towing insurance coverage Short Blocks (6009/6V009), Cylinder Heads (6049/6V049) and Crankshaft Kits (6303/6V303) for Gas Engines
• 12 months or 12,000 miles from warranty start date, whichever occurs first. Ford will cover 100% of all parts and labor at approved warranty reimbursement rates
Warranty Start Date
• Ford and Motorcraft Remanufactured Transmissions and Gas Engines installed by the Dealer or Installer—warranty begins on the date of installation
• Ford and Motorcraft Remanufactured Transmissions and Gas Engines sold by Dealer or Installer over-the-counter or to a retail purchaser—
on the date of sale
Limitations to the Warranty
The following limitation applies to the products covered by this Limited Warranty
• Towing charges are not reimbursable for Ford and Motorcraft Remanufactured Transmissions and Gas Engines sold
over-the-counter by a Dealer or Installer..."
read more incl the;
"No-Risk" Core Return policy means accurate quotes for engine and transmissions are no problem. 100 percent core credit will be given (regardless of damage or quality of returned core); just follow these guidelines and the return runs
smoothly.
• Returned core is the same part as the assembly purchased
• Core is 100% complete with all parts attached and all fluids drained and is returned in original package..."
Also;
For any tranny job incl replacement; re-gasketing etc.
Filter, In-Line TSB 00-23-10 for 89-96 Bronco & F Series, etc.
Source: by Ford via by thedieselstop.com
Filter, In-Line, Emerging Enterprises, Magnefine® or Power Steering XC3Z-7B155-AA Installation Instructions; Ford XC3Z-7B155-AA; this filter is cited in E4OD/4R100 Filter, In-Line Kit TSB 00-3-8 for 89-96
Source: by Emerging Enterprises, Magnefine® emergingent.com
Filter Magnet; E4OD Kills Engine in Gear; "...works as a filter retainer; w/Ford PN and size; basically this is a magnet Ford uses to keep the filter in-place tightly into the pump; Ford pn F3RZ-7E290-AC..."
Source: by spxfiltran.com via web.archive
Filter Clip Alternative; "... have seen many threads and received many pm's as of late speaking of the stay-put filter clip used to keep the filters from falling out of the pump in the e4od. there is an alternative to using this clip. it is more expensive but also has more benefits than just using this clip. you can get a trans pan from a 03 super-duty truck. this pan has little humps in the bottom to but up against the bottom of the filter and this keeps the filter from falling down. this pan also has a drain plug and extra capacity for 1.5 more qts of fluid. this pan also allows you to use the much better elastomer gasket. it is reusable and virtually leak-proof. much better than the cork design. it does require the use of a 4x4 filter..."
Source: by thePUNISHER (Paul) at FSB
Filter Clip pics in a 96 5.0
Source: by Tony K (Boat Dude, Big Blue) at SuperMotors.net
Filter, Internal, Grommet Warning; "...When ever you go to change your trans filter, Always make sure to pull out the little round rubber do hicky thingamabob. Lets call it a gromit or a seal? Theres this part of the trans filter that is inserted into the trans (a round tube that goes up into this hole ); Now the tube has a gasket of sorts that wraps around the tube ( kinda like a wide O-ring )It form a seal between the tube and the hole it goes in. Well what ended up killing my trans was that fact that the last guy that changed the trans filter didnt notice that this o-ring thing (gromit Or what ever) did'nt come out with the filter it stayed in the hole! He left it in there; & installed the new filter witch had its preinstalled gromit already; So what he did, is he (unknowingly) stacked two gromits on top of each other, Witch did not let the filters tube fit as it should. It was starving itself for fluid!! It was sucking air as well as tranny fluid! (in other words not working right) ..."
Source: by BlancoBronco (Cam C , Project BLANCO) at FSB
Satyr of the Midwest
Eh, doesn't look that bad, 'cept for the chunky stuff.
FSB warrior
mine had a half inch of sludge in it, it still works though.
1 - 10 of 10 Posts
