yo,
Also,
Shift Indicator Adjustment in a 91; "...Well I got it taken care of but there wan no knob to be turned...no black tube either. There was a white plastic tube that has a cable in it....that was mounted around a plastic pin that is attached to the steering collum(sp?). There was a small amount of adjustment that can be made by the mounting screw that holds the plastic tube to the collum. The mounting bracket for this has a slot where the mounting screw is. I just loosened this up and adjusted it accordingly but.....it still wasn't enough. I actually had to put a O-ring around the pin that the cable gets attached to make up the difference that I needed but now it all works perrrrrrfect!..."
Source: by h8nlife (Ted W) at FSB
