1 - 2 of 2 Posts
hey guys, tommarow im installing a new transmission mount but im not sure oof the exact procedure. do i have to remove the crossmember and support the tranny by a jack stand? where should i put the jack, on the pan? im somewhat comfused as to what im supposed to do so any info at all that you can give would help allot, thanks in advance,
david sickles
CheeseBurger Milkshake!!
It's been awile since I've change one......if I remember correctly, the crossmember has to be unbolted and slid back before the mount can be changed. The transfer case can stay in place.
If you decide to support the trans by the pan, use a 2x6 on top of the jack to help distribute the weight, reducing possible damage to the pan. You might also be able to support everything with the t-case.
Good Luck!
1 - 2 of 2 Posts
