1 - 20 of 24 Posts
Hello. I have a 1994 Ford Bronco XL. Not sure exactly what transmission I have but I do know that it is a 4 speed Automatic. When driving down the road it feels as thought my transmission kicks into neutral and after a few seconds of my motor revving to the moon, it slams into gear. It usually happens so fast that I cant take my foot off the gass in time. Any suggestions??
The thing is is that sometimes it shifts just fine. But others it shifts real hard. So I'm not entirely sure where I should begin looking
Service before Self
I had a similar problem with mine. It seemed to shift into neutral then when I stepped on the gas it would rev and them slam back into gear. It wound up being my transfer case. The shift fork broke and it was slipping into neutral when the drive train got slack in it then it would slam back into place when I stepped on the gas. It happened when I was on a road trip and still about 4 hours from home. It made it the rest of the way back but the problem kept getting worse and it grenaded when I got off the exit ramp at my exit....
Satyr of the Midwest
Have you tried the "Search" function yet? :toothless
Discussion Starter · #12 ·
I have never heard of that but in either case I'll have it checked out. Any other ideas on where to look?? I appreciate all the help by the way
Discussion Starter · #20 ·
My dash lights work fine. Everything works just fine. I just need to get that problem checked out. I'll try and have the codes yanked this weekend
1 - 20 of 24 Posts
