1 - 20 of 31 Posts
from every thing i've read the e4od blows, and i wanted to swap it out, what would be the draw backs/advantages of putting an AOD in, or is it even possible or worth it?
Hmmm, I have the same question. Can't wait to hear the answer.
or how hard would it be to swap in a c-6, what would i need?
Ford Hoarder
78 & 92
I wouldn't put anything but a c6 in there unless you have to have overdrive
I plan on doing this swap on my 92. From what i have read the drivshafts will be wrong, the crossmember needs the mount moved, the tcase linkage will need re worked, there should be some sort of kick down, and you have to have a manual tranny computer, i think.
what about for the AOD? i really want an auto trans with o/d for my DD.
Roller rockers are gay
AOD was never supposed to be behind a 351.
i agree that i have read a lot of the E4OD being a hunk of shit. but i have also read that when they are built CORRECTLY, they are unstoppable.
in short, when they break, they break bad. when they work they're awesome.
my opinion? swap a zf 5 speed in that thing.
you know where i can get one, used or new i dont care im just looking for a good dependable trans for my DD.
for any trans other than the E40D you dont need a new eec if you dont want, but u will pull trans codes, makes sure w/e trans u get, u get a flexplate for that motor that matches that trans, c6 needs a vaccum line for the kickdown iirc, and a tv cable, either new crossmember or modify old one, and driveshafts
well how much work/money is it going to take to get a c6 and get it installed
Discussion Starter #11
what about just doing some mods to the e4od to prolong life, what can i do and how much will it cost?
Designated Tranny Killer
I love my AOD.
dave
search and you shall find, #1 killer of that trans, or any trans for that matter is heat, get a better cooling system and an external filter, theres a ton of info on here about that trans
and for anyone looking for a c6 swap, search for "reviving the turd", long but informational
Practicing Infidel
I agree going backwards to an AOD
may be a move in the wrong direction, EVEN THOUGH many places can build and re-engineer an AOD to withstand 1100 horsepower. Truth is they can also build your trans to take it too.
Try these people and read how they do it;
Lentechautomatics.com
As for going to a 5 speed manual, not for me. Anyone who has wheeled and manual and auto, knows they'd rather wheel an auto.
As far as a C-6 goes, yes if you're a weekend only truck. NO if you're a daily driver.
Sixlitre
Discussion Starter #15
i know i can probably find something if I search but can someone tell me where i can get the best transmission cooler for my 351w?
A E4OD has alot of simularities with a C-6. I have heard it called a electrical C6 with o/d. The cost to buy a stought E4OD is pretty high. I have seen a average of about $1600.00. A stought AOD is cheaper and can be as strong as a E4OD or a C6.
If you have to have O/D, I would recommend you just have your tranny rebuilt with a high quality kit. The newer E4OD's have solved alot of the earlier problems that have given the E4OD a bad name, and the high end kits include these improvements. Larger Bands, kevlar clutches, etc. A high quality rebuild and a improved cooler and filter will make a great combo. just my $.02
Discussion Starter #18
green ones make me horny
Not hard at all, but look into B&M cooler. they are thicker and will cool better.
also look into a remote filter.
ken
Discussion Starter #20
cool, but where can i get a B&M kit, because i need every thing, and any brand or model suggestions for a remote filter
1 - 20 of 31 Posts
