Age. Fac ut gaudeam
Yeah, search is kinda lame IMO.
I get better results at the make a thread window, then type in your title... Once you go to the main body multiple options pull up with related terms.
With that being said, I don't know of any 8in suspension lifts.
Your sig says you already have a lift though. :/
Age. Fac ut gaudeam
green ones make me horny
Double posting is kind of lame too....lol just kiddin
skyjacker is the only 8 inch ttb lift i know of
shibby
You'll have to piece together a lift through trial and error.
Front-
8" Fabtech springs for a 2wd F-150
Your preferred 6" axle pivot brackets and extended radius arms
The proper length shocks
Drop pitman arm or tie rod flip
Extend the brake lines
Rear-
Shackle flip
6" lift springs (actually results in 4.5" of lift)
Proper length shocks
That's pretty much how I had mine set up.
I guess after 5 years on the board - I still don't know how to search effectively...if you type 8 inch lift into search - it'll tell you "The following words are either very common, too long, or too short and were not included in your search: 8" and it'll search for inch and lift..8+inch+lift doesn't work....neither does enclosing the term in quotes.....
And yes - I already have a lift - 6 inch suspension and 2 inch body.....but I want more 'eh ?
Dan
