1990 351. Check supermotors sig. if you need more info.
Go to start it up the other morning, it starts and then dies after running very briefly (a second or less). I can turn the engine over but doesn't start at all. :banghead
I figure maybe I made a miscalculation when reading the miles on my odometer (which is how I track how much gas I have because I have the same gas gauge problem that so many of you have), so my first thought is to put in gas. Put in gas, still no start.
I have tried a couple times since then and have the same problem, engine turns over, but no start.
Today I just tried to start it up and it did the same as it had before, started and ran very briefly, then died and would not start back up again. This time though, as I was trying to crank for a start, my RPM gauge was going crazy. As I cranked it would first go up to 1000-2000 RPMs for a second, as it usually should, but then fired back down past 0 RPMs and out the other side into the 5000 RPMs. So basically its turning backwards as I try to start it.
Anyone have any idea what this could be? :whiteflag
Oh, and if it's of any importance, we have had a recent weather shift here and are now consistently into the 10's and 20's.
