As most of you may know, I recently bought a ’90 F-150 with a dead cyl and swapped in a well-running, known good motor in its place. The truck runs fine anytime I am on the throttle, and the problem happens mostly when I am trying to park the truck. It will die almost every time I am backing up trying to get into a parking space. The truck has a solid idle, around 650RPM, if I am stopped in park and after I shift it into reverse. It usually goes something like this: place into reverse, touch the gas pedal enough to get moving, let off the pedal, start to slow down and the RPM drops to almost zero, then it will jump up to about 1000RPM (as though the computer is trying to keep it from dying), then it dies. This only seems to be a problem if the truck is warmed up already. A less common occurrence is when the truck does this when I am moving forward. It doesn’t happen all the time like it does in reverse, but it does happen often enough for me not to trust it when I’m trying to make a left turn across traffic with just a green.
I do have a leak in the passenger side header/y-pipe connection, but I fail to see how this would cause this problem.
I replaced the throttle body complete with the TPS and IAC (idle motor valve) with known good parts that I had lying around. No change.
I just installed new (less than 500mi ago):
Cap, rotor, plugs, and plug wires.
MSD coil
Set timing to 13.5BTDC (it has much better pick-up after this nice little mod)
Ghetto FIPK
PCV valve
Rebuilt injectors (a shameless plug for Mr. Injector, good injector rebuild kits)
I don’t see how any of these codes could cause the problem, but here they are anyway.
KOEO (my CEL is never on for more than a few seconds, but sometimes it will come on for a few seconds after I start the truck or intermittently when I am driving it for a few seconds):
34-PFE or EVP above closed limit .67V (btw, what in the hell is the PFE? Does this mean my EGR may be stuck partially open?)
CM:
34-Intermittent PFE or EVP
51-ECT > 4.6V
KOER:
21-ECT out of range .3-3.7V (I think that this one was my fault, the engine wasn’t completely warmed up)
44-Thermactor air injection system inoperative
25- Knock not sensed during dynamic test (my timing was a little retarded when I did this KOER, so I’m not sure that this really means anything)
Could that Code 34 be something meaningful? Maybe my EGR valve is stuck partially open and the truck is starving for fuel when I let off the throttle. That’s my wild ass guess anyway.
MSD coil
Ghetto FIPK
PCV valve
CM:
51-ECT > 4.6V
KOER:
