HELP!! I have an 85 FSB with 6" suspension lift. I added the Daystar 2" coil spring spacers and would like to know if anyone makes an Axle Pivot Bracket extension that will bolt on to the existing superlift brackets to make up for the extra 2"s.
Wrenching for a Livin'
i think you would need to get 8 inch drop brackets or have them custom made.
Gaknar,
Yes the camber is bad. I bought the adjustable camber bushings from Pro-Comp, but couldn't ge the old ones out....You have a nice ass Bronco by the way...
The Anti Yam!
SigP229 said:
Gaknar,
Did you take it to an alighnment shop?
I run 2" spacers in my TTB ranger and it was able to be alighned.
I use to run 2" spacers in the Bronco and it two was alighnable.
Both required the most ofset camber bushing avalable, but they where alighnable.
