Check out this ttb burban :uke: :uke:
The stock GM front axle was replaced with a Dana 44 Twin Traction Beam setup from a Ford truck.
i think my sig lines says it allEXCUSE ME SIR IS THAT YOUR 5 GALLON BUCKET OF COMMON SENSE THAT YOU JUST DROPPED
Hdpsd said:what about this bronco? 35's 460 and 8.8 :uke:
no, the tubes are inherently weak, and there is nothing that a truss is going to do about tubes that are only 5/16" thick. the truss is only going to help the tubes where they meet the housing and to possibly keep them from spinning. the ring gear on 8.8s is very burly, its the tubes that are the problem.BigBad94Bronco said:I bet that 8.8 holds up perfectly fine running through the sand in that truck , especialy with the upgrades done . The only time an 8.8 becomes weak is when you try and run too tall of a gear .
:stupidPony-boy said:Hmmmmm. I like the clean interior work
