1 - 10 of 10 Posts
Ok so now that I got all my other stuff squared away.
I looked on JBG under Dana 44 and it list one spicer u joint, is this the replacement for all the u joints? Meanin are they all the same?
And I believe there is a left outer and right inner and outer
Thanks again everyone, sorry for so many questions but this is a big chore
Yes, in any of the full size TTBs all the joints are the same.
Thanks appreciate it, I'm going to order 3 spicers from JBG
aka: kemicalburns
looks to be. I am running Spicer 760x if I recall. we repacked the caps with hi quality CTM ujoint grease. after we installed the ujoints we put small tac welds on the caps/axle ears. this helps keep the caps from spitting out. when wheeling this front end takes abuse.
Can anyone confirm this is the right u joint
http://shop.broncograveyard.com/mobile/D44-Dana-Spicer-Axle-U-Joint/productinfo/32072/
Again I realize I'm making it too complicated but I'm making sure I have the right parts before I tackle this job.
I have to do it on a Sunday and don't want to be running around to the parts store all day
So, you plan on getting ALL this done in one day, spindle bearings, ball joints and U joints?
Another thing you are gunna need, is a 6mm 12 point socket
No I'm actually trying to plan on doing it on a three day weekend,
Start sat afternoon after work and work sun and Monday on her the Tuesday morn off to the alignment shop
Ok so after a day of searching I finally found the right spicer part number I believe, apparently carquest is the only parts store that regularly deals with spicer,
So from what I found I need 3 spicer 5-760X u joints
Kem you were spot on
Ultra Premium Member
I checked mine at the shop last night, those are the correct numbers.
Thanks guys just down to buying rotors and pads and I'll have all my parts,
Ordered three of the spicer lifetime u joints 90.00 bucks
And got 150 dollars worth of front end seals,
1 - 10 of 10 Posts
