1 - 18 of 18 Posts
The Anti Yam!
I am doing a SAS and am just wondering if anybody uses the TTB radius arm bracket?
The only person I have ever seen do an SAS and retain the original mount is Oscar. But thats becouse he moded his rancho extended TTB radius arms to work on a solid axle and the Rancho arms reuse the radius arm bracket, relocated further back.
So the short answer is no. You can't because they don't use C bushings like the solids do. Shorter answer is sure you can if your a master welder.
EDIT: oops miss read the Q
Crusher Mike
Im pretty sure you can it has nothing to do with the C bushings. The shaft on the solid axel radius arm is larger than the ttb radius arm if you can get the bushings to fit it may work.
The Anti Yam!
So the short answer is no. You can't because they don't use C bushings like the solids do. Shorter answer is sure you can if you a master welder.
I think you misread his question.
I tried using the TTB brackets because the face of them is angled back to help keep the bushings "un-bound" at ride height.
But, alas they brought the bushings in too far and caused more bind than they helped. I never even got them spread far enough apart to fit on the frame, even with the C cap bolts loose as a goose.
I ended up using the 78 mounts and cut 20 degrees out of them. They work much better gooder.
Discussion Starter · #8 ·
The only reason I am asking is because I will have 8 inches of lift and 7* bushings so I figured the TTB brackets would provide some drop.
Discussion Starter · #10 ·
Yes I do. I was refering to the stock brackets dropping the radius arms a couple inches but I do have TTB drop brackets aswell.
Discussion Starter · #16 ·
If I angle the radius arm bracket 20* would it be possible to use 10" lift springs without radius arm drop brackets?
Discussion Starter · #18 ·
Yeah that is what I was thinking. I already have the 8" springs so I am just going to stick with them to save some headaches and I don't need the extra lift anyways.
1 - 18 of 18 Posts
