1 - 13 of 13 Posts
Since I go through shafts like food I am always looking for replacements. So far everything has worked. But I remember a site I found a year or two ago that had the specs of the TTB shafts. And I remember the dimensions changing slightly over the years. Like the late 80's shafts being 1/2" shorter than others. Some stub shafts being slightly longer than others, etc. Was I dreaming or is this the case? If it is the case will they still work for me because I don't think they will? Thanks. Posting this on FSB also.
Diesel Gynachologist
trying like hell bud, should have a soild anwser in a few days. this whole moving thing hit at the wrong time!!!
if by chance I cant make it I will give the shafts to scott(dogonmut) to bring up to you
Charlie don't surf..
'92 Ford Bronco XLT
I was looking at the tech link dustball posted and it lists two different left hand assy for the '92. The first one is 71394-1x which is '88.5 - '92, and the second is 74813-1x which is '92 - '96. I checked the measurements for the two and every thing is exactly the same, except for the measurement on the inner part of the shaft which is 15.69 on the one and 15.68 on the other. Will that make that much of a difference, or can I run one from either year without a problem.
Here's the difference in the chart, highlighted in green.
1 - 13 of 13 Posts
