1 - 2 of 2 Posts
So I own a 1996 F-150... not a bronco I know but we have the same stock front axles and my truck has been used off road.
Anyway long story short.
my passenger side axle shaft is rubbing in the ttb housing... if that makes sence the whole wheel is pushed back about oh a inch its not sitting right with the wheel well.
upon further inspection my stock rubber bushing for the radius arm is crushed. so basically the whole front end on the passenger side is moved back about an inch....
so if I replace that bushing I have had 1 mechanic tell me it will not fix the issue, and make it worse as your moving the beam forward not the axle.
the other one told me it would make it alright. I have lived with this for 2 months now I need help :(
thanks guys :)
si vis pacem, para bellum
well the bushings need to be replaced regardless so i would go ahead and replace them and see what happens
1 - 2 of 2 Posts
