I replaced the ignition actuator rod and it looks like someone has been there before. I don't have tge collar that installs over the steering shaft right between the signal switch and bearing. I was wondering how important this piece is or what it actually does. I nedled to get my truck running asap thanks.
Discussion Starter #2
Also notice how the switch sits a little too forward. I can't tilt the steering wheel because the lever touches the plastic before the tilt mechanism.
...tge collar that installs over the steering shaft right between the signal switch and bearing.
Do you see it here?
http://www.supermotors.net/registry/media/894815
Last time I rebuilt mine, I bent that rod (it takes a LOT of effort in a vise because it's hardened) so it's always pressed (lightly) against the blinker stalk. That makes unlocking the tilt MUCH easier.
I figured it out. I took a class at university of wrecking yard, and dismantled 3 of them. It was tge snap ring not seated right
So i got it all together but i tightened up the steering wheel nut and the door chime now goes off whenever the door opens. Even with the headlights off and key out of ignition.
