Ok, so I had every turn signal and driving light working except the front drivers TS, which would only blink if the driving lights were off. If the driving lights are off, it will now cause the two small side marjers lights to blink when I turn on the switch. At the same time, my rear passenger yurn signal no longer works! It worked fine until I unplugged that front drivers side 4 prong plug. Conversely, the rear drivers side turn signal works fine with the front plug unplugged or plugged in. So, I believe the front 2 hole, 2 prong plug could be grounded inside the plug itself. Does this sound like a reasonable deduction?
Brake lights work both sides
Backup lights work both sides
Tailights work both sides
All driving lights work
Front Turn signal causes the two drivers side side markers lights to blink now.
Rear passenger turn signal stopped working when I played with Drivers side 4 prong harness connector.
With front harness unplugged, rear drivers turn signal does not cause side marker to blink, only when the front harness is plugged in
Headlight connector is not connected as I have made a different harness for those already.
Should I cut the 4 prong connector and hard wire it to see if it is the connector itself? Or is the turn signal switch going bad?
1978 Bronco.
Thanks!
1978 Bronco.
Thanks!
